A 4.4 NAS L322 came in some 5 weeks ago for oil leaks, bushes and some aircon problems.
Hence they took the dash apart to get to the evaporator.
Today the boscalled me.. no start with a nivcely charged battery.
Found several unrelated errors, cleared them.Nothing.
There is 12V at the 3 relevant engine ECU wires in ignition pos 3. (C0331)
but no start.
So I thought it has Alzheimer and connected my Hawkeye Pro to the diagnostics to resync the engine and immo. No problem. (still haven't found it in the GAP but I'm probably blind)
Then I went trough all live data.
Every single thing si fine but the starter motor says in gear and disabled..
Been checking a lot of other things like fuses. Nope.
Any thoughts welcome
Discussion Starter #2
this is what I did. The question is, why did I have to do this. Immobiliser ECU thinks the car is in gear, but it isn't , gear position appears on the dash, all is fine but I need this silly connection. Both EWS and Enine eCU agree that the car is mobilised
Any ideas?
