Hey Guys, I need to replace a couple tie rods and ball joints on my rover, this will be the second replaced set and I'm sick of not having grease-able joints, is there any way I can get moog parts or some high quality tie rod end and ball joints with grease fittings?
thanks guys
Banned
Don't buy cheap Britpart ones this time, buy some OEM ones and you won't need to replace them for another 15 years or so.
Banned
Lemforder seem pretty good quality, I've got a Lemforder tie rod on mine and it seems to be well made. It was a bit more expensive than a Britpart one but my experience with Britpart is that it is ideal if you enjoy replacing the same part over and over again.
Lemforder became an official supplier to LR - across the entire range -a couple of years ago, and if for example you were to go into a dealer to buy your front axles' top and bottom ball joints you'd get a nice brown box and inside - if you look closely - you'd find Lemforder markings. (so you could save yourself a few quid)
In other words give genuine parts a go.
