I am hoping that someone has some suggestions on this - I am stumped!
after driving my 1999.5 SE for either short or longer distances, a very strong fuel smell is present in the rear of the vehicle. It is bad enough that it permiates to the upstairs bedroom when I am parked in the garage.
Last week, I went to investigate, and dropped the tank, cleaned, and inspected. the side of the tank had signs of fuel running down, but not enough to cause a leak on the ground. the main fuel line was well connected, but the vapor return line to the fill tube had come detached from the tank (although I am not 100% sure the this did not happen when I was removing the tank. Also, it did not appear that this fuel was coming from the gasket around the fuel pump.
I re-assembled everything and was hopeful that it was the disconnected hose - but alas, the smell is back.
I have not yet reinspected the top of the tank, but i am wondering if something else is causing this hose to come detached - pressure build up? or maybe the carbon canister is blocked or bad?
Any thoughts or suggestions would be appreciated.
