I get this error code when scanning the IPC on a 2011 Rover...I can't find any description on it other than it is a fan? Where is this fan located?
Can you give us more to go on? It is a fan...? well which fan is in the IPC system. Does the IPCM have a cooling fan? Does actual IP have a fan?
Sorry, maybe I didn't word it correctly. The touch screen unit on the car has been acting weird from time to time - switching inputs on its own. Other times shutting off due to heat. There are no faults in the car other than B12FE in the IPCM system (Image Processing Control Module). I tried to find descriptions for the code, but all I can find is "fan". SInce I live in AZ, and its still 108 outside, it makes sense that the fan may have failed, overheating the IPCM. The question was and is - is there a FAN that goes with the IPCM Module? Where is the IPCM module located?
