Hello folks, update on the autobox. Bought a used 4HP24 of unknown faults for £100, got the selector shaft out easy as just a roll pin to drive out (took the valve pack off just to see what was under), fitted it to my box without removing valve-pack. Had to cut a small hole in the footwell to get room to slide it in, blanking grommet afterwards to fill hole. XYZ position switch was the biggest problem, £50 for a used one, my later vehicle has a grey multiplug, which are less easy to find than the earlier black multiplug. If you are involved with the later grey switch, be advised that there are two types of XYZ with a grey plug, depending on whether a HP22 or HP24, I suspect. These XYZ switches have two mounting lugs on the alloy backplate, and on most switches they appear to be level, but on my switch and gearbox one lug is offset 6.4mm more than the other. This version seems to be fairly rare. Also needed a new front propshaft of course. One more bit of advice, when trying to align the gearshift linkage cable and selector shaft, the manual suggests doing this at "park". It is much more successful done at "neutral", as is aligning the XYZ without the factory tool. rgds Alan. PS sorry this is all in a block. Has anyone figured out why the "return key" doesn't work?
