I plan on replacing/repairing my non working exhaust solenoid. Is the solenoid repair kit on Atlantic British suitable for all the valves including the exhaust?
Maybe you have already confirmed the solenoid bad. But if there is any doubt, swap with one of the other solenoids and make sure the solenoid is really the issue. Or use a jumper wire to manually actuated the solenoid. I thought I had a bad one once but it turned out to be the driver block not sending the proper instructions. Replacing the driver block solved my issue.
