I have access to the workshop manual for a couple of days.
If you need the procedure for timing the engine, ask me and I will post it. There is too much to post it all.
2011 Range Rover Supercharged
I'd love the instructions for tensioner + chain replacement.
2010 SC 5.0 Range Rover MkIII / L322
please tell me the cylinder numbering for a 2010 5.0 SC engine
NOTE working on the engine cylinder numbering is different than the testbook layout.
and then what the cylinder numbering is when a scanner is connected to the engine.
Thanks i have asked a few times . because when the scanner says cylinder miss on 1 2 4 and 7 where exactly are these cylinders VS what the WSM says,
please include the left or right bank designation, Thanks
I've PMed you Bill
OK thanks is this also the same layout that the computer tester will give,
I think its backwards see if you can find what i am talking about
Discussion Starter · #7 ·
It should be the same. 1 and 2 are the front of the engine.
