1 - 1 of 1 Posts
Arnott® Introduces New Front Air Strut
for the '05-'09 Land Rover Discovery LR3, '10-'14 LR4,
and the '06-'13 Range Rover Sport
Arnott Air Suspension Productshasintroduced a new, not remanufactured, Arnott-designed aftermarket Right or Left Front Air Strut for the 2005 to 2009 Land Rover Discovery LR3, the 2010 to 2014 Land Rover Discovery LR4, and the 2006 to 2013 Land Rover Range Rover Sport, including supercharged.
Arnott's new aftermarket Air Strut for the Land Rover and Range Rover replaces OEM Part Numbers RNB501580, RNB501250, RNB501620, RNB501460, RNB501600, RNB501470, RNB000857, RNB000856, and RNB000858.
The Arnott Part Number is AS-2809 and it retails for $348.29. A detailed Installation Manual is available for download. The Air Springs are backed by Arnott's Limited Lifetime Warranty in North America and the European Union.
The Arnott Advantage
Designed, assembled, and tested in the USA, Arnott's new aftermarket Front Air Strut replaces the OE air strut and features a new custom-made shock absorber with a multi-ply Continental ContiTech air spring bladder. The strut also features extra-heavy duty crimping rings, new seals, new air fitting and check valve, and a black anodized aluminum top. The assembly is protected from debris by an aluminum can.
An Impressive Array of Additional Innovations
The featured air compressor is a high-quality, cost-effective solution for Land Rover owners concerned about failing air suspension parts leaving them stranded with expensive and recurring maintenance problems. However, 'The Arnott Advantage' does not stop there ... Arnott offers an impressive array of additional, innovative new and remanufactured aftermarket replacement parts for the Land Rover and Range Rover. The entire range of Arnott Air Suspension solutions for Land Rover vehicles can be reviewed Here.
UPDATE: Arnott no longer sells products directly to consumers so the discount code is no longer valid. Arnott sells its products through leading retail and online reseller.
1 - 1 of 1 Posts
