hammerma said:If they will replace all four may see if they would just pay for a coil conversion. Will see how it works out.
:crybaby2: another castration due to lack of information... so sadhammerma said:If they will replace all four may see if they would just pay for a coil conversion.
:thumb:hammerma said:If they will replace all four may see if they would just pay for a coil conversion. Will see how it works out.
You could go for GEN II bags and with the money you save give the compressor and valve block some new seals and replace the dryer dessicant. Will prevent most if not all of the problems you're afraid of without the need to castrate it.hammerma said:True, but there are alot of wear items to EAS. And outside of a complete overhaul which definately wont
be covered in warranty you still will have periodic failures which for me is not acceptable when im not
at home to take care of them. I like the EAS system, but I actually dont trust it. It seems to be the weak
link when the truck gets 10+ years old. Again if I didnt travel for work different story.
