Thanks for looking. The front diff was updated by the dealership 2 years ago and go figure.... its leaking.
The drivers side driveshaft diff seal has a bad leak. Is this a easy fix? How do you remove the front drivers side driveshaft?
I will be tackling this myself. Thanks
I actually need to do the same job on mine as mine leaks a bit too. Basically remove the hub. Then there is a special tool which clamps around the drive shaft just behind the CV. This allows the shaft to be forced out. Not sure if this is possible without the tool. RAVE also mentions renewing a circlip when reinstalling. I assume this is a clip which holds the drive shaft in the diff.
