Pulled off the cover of the steering column to fix the Gas door button and found this little 2-wire connector all by his lonesome. Any Idea what it goes to? i couldnt find anything in rave, and I am 90% sure it is OEM as it goes into the harness. IMG_20140806_094442.jpg
It's probably for an accessory that isn't fitted to your car. If everything is working, leave it. I would doubt that LR made specific wiring looms for every possible combination of additional options that could be fitted to the range. They probably just made one or two. If you are really bored, you could trace the colour code in the Electrical section of RAVE.
