Hi All,
I want to remove the cowl vent grill that mounts on the center rear of the hood (bonnet for those across the pond?). I'm sure there's a technical name for this piece, but hopefully you know what I mean. It's the part with the windshield wiper squirters built into it, and is satin grey on my '04 HSE.
The finish on the piece has worn off in a few places, and I'd like to remove it to repaint it.
Anyone have any advice for how to remove this piece without damaging it?
It comes off very easily with a few push fasteners. Just lift the bonnet, and you can see them. You can take a hammer and lightly tap them from underneath. The only trick is removing the washer jets without breaking them. I take mine off each new vehicle to mount the mascot.
That worked like a charm. Thanks for the tip!
Now I just need to figure out how to pull off the small silver trim strip that goes on the rear liftgate, directly below the Range Rover script. I assume it just mounts with double sided tape, but I'm not sure what tactic I should used to remove it. I'm guessing just hit it with some heat and carefully pry it off, but would love some feedback if anyone has any.
Yes, that small trim piece is held on with adhesive. The best way to take that off (or any of the letters) is to heat with a hair dryer and then use dental floss or fishing line. I like dental floss as the wax coating will not scratch the exposed paint work. I use this trick if the dealer "forgets" and puts their logo crap on the back of the car....
Best of luck....
Thanks for the tip on that trim piece. I got it off last night and cleaned all the old double-sided tape off.
I'm planning on stopping by the bodyshop tomorrow to drop off all the parts so they can be sprayed in satin black.
ASGIBM said:
...the mascot.
Cool Mascot!
I push the fasteners up from the bottom with a pair of long needlenose pliers, compressing where the fasteners bulge out for retention. I've heard people break the hood vent trying to get it off, and they're a few hundred bucks to replace!
So how do I remove the washer jets?? I was going to cut the washer fluid lines and pull the easy electrical clips on both sides until I saw those three little heater wires? I think.
