Need location of all brakepipe connections. Anyone with the ANR1118 Wabco ABS modulator ( with ETC) and right hand drive.
1992 to 1995. The RAVE workshop manual doesn’t show clearly.
Cheers in advance.
If you have a broken brake line
You can cut out the bad and replace useing compression fittings
Hi Mickieman, cheers for your reply. I’m using new nickel pipes throughout. The car was stripped 12 years ago... so I’m in need of a diagram of all unions around the ANR1118 modulator.
RAVE workshop doesn’t clearly show this on either right or left hand versions with ETC (electronic traction control).
There is a similar RRC with the same ETC set up, just down the road, but he also has issues with the set up.
Lol
Get myself in a crash
Not yet
I had a brake line rust in too
I used compression fittings to scab a piece of brake line in
As a patch
It’s still in tact
The Rover not so much
It’s parts now
But it held
I would do it again
