Since the front prop fell off a few weeks back, I'm a bit more paranoid about odd noises, and I've got another one.
Starts to get audible from about 40 - 50mph.
Turning left, all quiet.
Straight ahead, slight rumble.
Turning right louder rumble with some vibration felt through car.
Seems road speed dependent, and present in all gears and neutral. Sharpness of turn does not seem to change pitch.
This seems to me to point to a wheel bearing, but which one? Spent several hours last night with the car on a ramp trying to pinpoint source, but could not be sure. Certainly no movement in either front wheel bearing and think I can hear a bit of a noise, but have not managed to convince myself that the noise is not coming from the opposite bearing or the diff.
Logically, with the noise loudest on a right hand turn, I would expect the problem to be the left bearing, but at £100 a pop for the bearing, I would like to be sure!
Admittedly, I was convinced it was going to be a front bearing so did not check the rears. Will be doing that tonight.
So, any thoughts or pointers? Which bearings tend to go, front or back? Have done a fair bit of towing, which might accelerate wear on back?
I know this sounds daft, it really should be possible to pinpoint the source of the noise, but honestly, it's not that easy!
David
David
