This sounds like a valve driver problem.As you replaced it,I would check the power supply to the driver module,(12V and ground points) to eliminate this as the source. :think:
I will do that.John W said:This sounds like a valve driver problem.As you replaced it,I would check the power supply to the driver module,(12V and ground points) to eliminate this as the source. :think:
Yes. twice.Scotty said:Did you replace the pressure switch, what condition is the compressor in?
Scotty
Hi Dennis.shupack said:Compressor.
ALWAYS check the compressor FIRST. It is the most likely culprit of all EAS issues and the easiest part to fix....(for the benefit of future readers)
