I got a call from the Aamco shop that rebuilt my ZF 6HP28 the other day.
They said that they have another 2012 RR in their shop that they also found the splines between the transmission output and transfer case input rusted to failure, and asked for a reminder of where I found a source for the transfer case input shaft or the transmission output shaft - I forget which. I think it was the transmission output shaft because, oddly, I remember that ZF Eriksson had the transfer case input shaft, but not the transmission output shaft. So I found the transmission output shaft available from Cobra Transmissions, in Sebring Florida.
But anyway, I find it interesting, but not surprising that they are repairing another occurrence of the shaft failure, apparently from LRs failure to properly apply spline grease to the junction of the input & output shafts.
And as far as my transmission since Aamco repaired it, it's operating great; shifting smoothly and flawlessly - granted only a few months after the rebuild, but nothing to suggest that the Amsoil Synthetic transmission fluid would cause any shifting problems. Of course this is with all new friction plates, solenoids and other parts that are replaced with a rebuild.
I expect to get many years from this transmission now that the failure built-in by Land Rover has been repaired, and the transmission is now BETTER than when it first came off of the production line.
