As my post title says,but i have a problem that has me baffled.
The truck has had a leaking rear air spring for a couple of weeks,but of course i had to wait till i get an EAS hard fault before i decide to replace it.
i fitted the spring yesterday and went to my indie to get the fault cleared,which they were unable to do( i asked and received some answers from the diagnostics forum about that issue)
my problem is this,i manually pump up the springs,and the front pair go down again after i switch of the ignition.'
i removed the delay timer,but the front still slowly goes down.
i have checked for leaks and have not found any.
my question is this,
why would both front bags go down?
i can understand if it was a sticking valve in the valve block,but wouldnt only one corner then go down?
any thoughts on this would be welcome,as tomorrow morning i am taking the valve block out to check it.
