My RRC 83’ has intermittent starting issues. When the key is turned the start solinoid always clicks, however the starter motor does not always crank.
Sometimes it May take 5 or 6 turns before the starter engages. Once it does she fires into life without problem.
Is this likely an issue with the actual starter motor?
Yeah I agree if your starter motor works intermittently your alternator is on the way out. To solve your problem I would change the power steering pump.
I agree with these guys. Starting is dying. The good news is: replacements are a lot cheaper than they used to be, and, it's a 5-10 minute job.
