1 - 20 of 136 Posts
Having owned my AB for a few months now i'm starting to look at options to at least get better Nav on the main screen and better music integration/control and I've come across this
https://youtu.be/ZZS4wiJdBgY
https://4x4shop.ca/product/vogue-land-rove...n-android/
I know it's a lot of money but if it does what it suggests it does I think it is worth it.
This appears to the only other solution ( other than the NavPlus option ) that I can find
Like the idea of an OEM looking 10" screen with proper functionality
Si
2013 & 2016 L405's
Re: Apple CarPlay for older 405's
Interesting...please keep us updated and let us know how well it works if you decide to get this screen. I wonder if it's all plug and play. It would be nice to update the screen in my 2013 L405 and have Apple CarPlay but for $1,550 it would need to work just as good as my existing screen if not better.
the title is misleading. this thing doesn't give you CarPlay.
I've ordered one from now from the manufacturer so will report back and maybe do a video on the install
Si
So i've had an exchange of emails with the manufacturer and wanted to share what I've learnt thus far
The kit you buy seenms to be a 10.25" screen that has Android built in that. This screen has the same back enclosure as the Standard Equipment and the way you keep all the original functions to is remove the 2 internal boards from your Headunit and put them inside this new screen ( headunit )
This seems a simple job TBF as shown in this video
https://youtu.be/JpamFhCet60
The kit then has a wiring harness ( to make it Plug & Plug ) with the addition of a Mic ( I assume to allow you talk to the Android OS Apps ) , GPS Receiver ( I assume so the Andriod OS APPS can use GPS ) and a GPS Speaker ( which I'm told is for the GPS Audio but I don't understand why this won't come out through the speakers )
See the pics for the kit
So, install seems very simple and totally stock ( except a MIC )
Obvisouly this kit doesn't offer CarPlay out of the box but as it's an Android Headunit adding this dongle seems to adds that functionalty
https://www.redmondpie.com/apple-carplay-u...r-any-car/
These are the questions I've asked along with the asnswers I received
Q Do all original functions still work like Climate Seat control, Massage seat control, Ambient Lighting control, Surround Cameras etc ?
A YES
Q Does the OEM voice control button work with Siri in Apple Car Play mode?
A NO
Q Why does the his new unit need GPS Anntena, GPS Speaker, External Mic as all these things should be passed to the headunit from the OEM cabling ?
A Because this android head unit system is independent from the original multimedia. And the original multimedia's functions will remain
Q Does the original OEM Nav still function ?
A The OEM Navi will work as usual.
Q Also, does this support Apple CarPlay via the OEM armest mounted USB port ?
A I don't think it support Apple CarPlay via the OEM Armrest Mounted USB.
It supports aftermarket CarPlay Dongle. Its price is US$60.
Q I’ve looked at your advert and I don’t see where a USB port is, I see a wiring harness, I see a GPS receiver, I see a MIC and I see a GPS Speaker ( but sure what this is for ? ) but no USB port
A check attached please.
It has 2 USB ports.
Q There is no Microphone is that kit, is one not required ?
A The mic will be included
Q What is the purpose of the GPS Speaker ?
A The GPS speaker will be used for navi voice.
Q I’m right in saying that the 2 black panels either side of the existing display that had soft buttons are replaced with virtual buttons on the new 10.25” display ?
A yes the screen will be replaced with 10.25" full touch screen.
Q Does the audio that comes out of the Android system ( for example if you’ve installed the App Spotify ) come out of the car audio or the GPS speaker ? Why is there a speaker just for the GPS audio ?
A Because the connection will be via AUX.So the speaker is just for navi voice.
Q Do all the steering wheel controls work when using the android system or if the carplay dongle is attached and car play is active can a phone call be accepted and cancelled using the steering wheel controls ?
A Yes
Just for clarity, this post above should have been posted a week ago but as I'm a new memeber it got lost in the spam capture jobby
Yes I've ordered this kit along with the USB CarPlay & AndroidAuto Adaptor my title is valid
The kit should take a few weeks to arrive but I'll post back
Si
2013-2015 Range Rover Sport
Please message me as soon as you have this all working and can do a video demo! I am very interested in this route for my 2015. I am interested this running in carplay only and also curious how this would affect the SAT radio that the current setup provides.
2013 & 2016 L405's
I'm mostly interested in the Apple CarPlay but it seems like this unit is not exactly set up for that. Also, I would want to use the existing USB in the center console to connect the iPhone for CarPlay...wireless CarPlay would be even better. I wonder if the 2017 screen would work in the 2013-2016 L405's...
you could wire up the armest USB port to the USB port from the CarPlay adapter
I have wireless carplay in my BMW and it's deffo the best solution but everything i've read seems to suguest it's not possible :-(
I'll ask the supplier his thoughts
Si
Looks intriguing. I would love to see google maps with traffic on it come up. I might get one then.
2013 & 2016 L405's
Si
I don't like the idea of having to access the glove compartment for the USB CarPlay adapter. It would have been much nicer if they would have made it plug and play for the center console armrest USB port as well. Overall, this unit seems to have good potential. Keep us updated!
Discussion Starter #15
I guess you could workout the cabling for the armrest and move those pins over to use the usb in the armrest but I think they are trying to leave you with everything that you have now still fully functioning and if they took away the usb you couldn’t update the maps, plug in an iPod etc, I admit the features are limited when the screen upgrade has been done but I think that’s there plan
As for CarPlay in the glove box, the module that plugs in to the usb isn’t very small so might not be a great fit in the armrest and I know from my own experience of using CarPlay in my 7 series 4 hours a day for the past 18months, then I get in the car my phone is out away in the charging cradle in the armrest so I’d be ok with putting in the glovebox. Apple CarPlay isn’t really geared up for you trying to use your actual phone when car play is being used
Those are just my opinions btw
Si
2013 & 2016 L405's
I've emailed the sales department so I'm waiting on a reply. I'll probably order it and do a little experimenting with the cable for CarPlay to the USB in the Armrest. I think the 10.25" screen itself would be worth a try because it appears to be a little nicer than the factory screen.
Discussion Starter #19
Oh sorry misread your message
Yeah I also emailed them, they replied asking for details of my car and pictures but that was the last I heard
I then went direct the makers
http://www.canaviet.com/
Si
2013 & 2016 L405's
Si
I just watched that video but couldn't understand a word they were saying. However, it appears that this unit does do screen mirroring which is a good feature as well.
1 - 20 of 136 Posts
