1 - 1 of 1 Posts
I acquired my Range Rover P38 about 2yrs ago and have now just got round to trying to sort out a problem that it has The sound system does not always work like it should 1.You start the car and turn it on no sound whatsoever and then full volume after a minute or two
2. You turn it down no sound and turn it up again after a while you reach a volume that is acceptable
3. You then go from Am TO FM and the same thing happens
I have had the Rad Cas head checked and the Cd player and obviously the amplifier that is behind the sub woofer in the boot and all ok so before I go crazy was wondering if there is anything else I can check before I rip the lot out and start a fresh
Gav
1 - 1 of 1 Posts
