I have my 4.6 engine out due to porous block problems and plan to replace the pressed steel sump with the later (Thor) alloy sump. I have searched the forum and other peoples experience only refers to needing longer bolts for the sump to block fastening. I have offered up the sump to the block and all looks well although I also need longer studs on the base of the timing gear cover to allow for the thicker alloy sump.
Does anybody know what I have to do the bell housing to be able to bolt the alloy sump to it where it replaces the original 'convertor drive plate access cover'. (I have the regular ZF auto box).
