After a short drive, ALL FOUR brakes seized solid this morning.
i released the pressure on the braking system and disconnected the ABS gave her two mins and she drove home with not a problem.
Now some history, same thing kept happening a couple of months back: all brake pads, discs, callipers replaced, all four wheel speed sensors replaced
So my question is where do I go from here, if I leave her for an hour or so and connect abs back up she will drive fine for a few minutes and then same thing happens all four brakes seize again.
Now...………………Could it possibly be the YAW sensor or am I looking at a new ABS pump, any help would be greatly appreciated?
No clue but since they've seized once you figure out the root cause you'll want to replace the rubber brake hoses at all 4 corners. Once the seize like that, send overheated fluid through, they're on borrowed time.
Agreed with Brad.
I have not had many issues with brakes, but I have read a good bit on the ABS modulator corroding or needing to be rebuilt? False signals from a failing unit would definitely cause the brakes to lock up as if ABS was trying to work with no wheels moving.
was thinking more about this... no codes right? It couldn't hurt to pull the plug off the ABS and inspect the condition of the harness. I completely forgot one of my old rigs had a similar issue (thankfully just in the driveway) and the harness was horribly oxidized... I cleaned it all up, refit back to working. I also had another issue with that rig (probably from the corroded harness) later where an ABS fault with trigger intermittently just saying there was some communication loss. I pulled the ABS module out, cut the casing open and visually inspect the board. I found one connection solder had melted and the lead had blown out. The whole thing is covered in some type of gel, I cut it away with a razor and re soldered the thing down, then just put silicone over the exposed area. That repaired the issue.
here is the ABS module with the top cut off it... I used a tiny cutting wheel on a dremel as they glue it together solidly.
