Gents, Is there an easy way to permanently disable the alarm system while still keeping the key fob entry? This system seems to be a little over kill
for us guys out in the country. Thanks
You bring up an interesting point.....:think:No. The alarm and immobiliser system is integrated with the BeCM rather than added on. They are turned on when the car is locked, even if you use the key rather than the fob. The only way to avoid setting the alarm is to not lock the car.
I have a GEMS and a Mobi, and Lee (from LAB (Mobi)) is working with me to come up with a 3rd party remote start & door lock system since Mobi already bypasses the BECM issue.You bring up an interesting point.....:think:
For those that hate the alarm system (And what's to like?) You could unlock everything, and just unplug all the door latches. Never will an signal be sent to the Becm to tell it to alarm.....8-0=
Then you install the aftermarket central locking system!
What could possibly go wrong?ray:
This could actually work, but I would never personally contemplate doing it to either of mine:naughty:
Mind you, if I had a Gems, it would DEFINITELY have a Mobi installed! They rock!:dance:
Alarm can be disabled electronically yes. removing, disconnecting or otherwise rendering the horn inoperative simply keeps it from making noise, the other elements such as immobilizing, light flashing etc. still remain active, thus by simply rendering horn inactive nothing is accomplished.I think you can disable the alarm with a Nanocom, you can also just pull the alarm horn off, or damage it so it doesn't make noise anymore, that's what I did.
Alarm horn is under the fuse box.
Could you give me a link or more info on this I am trying to find a way around every time I have battery problem my alarm disables my 99 P38 and I have to remove door panel and ground switch to get going again. Nothing else works for me.I have a GEMS and a Mobi, and Lee (from LAB (Mobi)) is working with me to come up with a 3rd party remote start & door lock system since Mobi already bypasses the BECM issue.
Pre Mobi, the PO had a new unlocked BECM installed, and simply disconnected the RF receiver---had to lock the driver's door manually, but no jumping lock issues (knock on wood). I'm simply looking to take that one step further.
Are there more info posted that I could look at on doing this.You can switch the alarm off in the BECM. The only part of the system you can't switch off is the immobiliser which is implemented by the engine ECU, not the BECM. The BECM just sends the mobilisation code to the engine ECU when the vehicle is unlocked/disarmed and the ignition turned on.
If you have a properly working drivers door latch, and have the alarm and passive immobiliser turned off, then you circumvent most of the issues that people run into. As mentioned above, there is a bypass module for the immobiliser for a GEMS engine ECU - but the Bosch ECU doesn't have a workaround, so at least requires a working door latch to tell the BECM when it's locked/unlocked so it can send the code through.
You need to replace the latch then so the microswitch grounds the wire as it was designed to do.Could you give me a link or more info on this I am trying to find a way around every time I have battery problem my alarm disables my 99 P38 and I have to remove door panel and ground switch to get going again. Nothing else works for me.
I replaced the latch the wiring and the Box inside the door.The only way to unlock the door is the key. When I turn the key clockwise it locks all the doors, when I turn it counterclockwise it unlocks the driver door but also locks the other doors. The remote only locks or unlocks the right door and both back doors. The latch was new from Partsgeek the wiring was bought from ebay I bought 2 sets and used the one I thought matched my burnt wiring. The outbox I think was new but not sure. None of this was a problem to me since I do not mind using the key. The issue is if I let the truck sit for a week or so battery is dead and I have to remove door panel and ground 2 wires to get it going again.You need to replace the latch then so the microswitch grounds the wire as it was designed to do.
I have tried all the fixes posted replaced all parts in door (I did let bad wiring go to long before replacing it and latch). The only fix that able to get me going again was removing door panel and grounding 2 wires from switch. Will look into updating RF receiver is this a replacement part or software update the closest dealer to me is 200 miles.What Richard said -- the driver's door latch must have a good connection. It sounds like you have a battery drain issue -- likely due to the RF receiver if it hasn't been updated to one of the later generations. There aren't any great work-arounds on a p38 -- but all the known issues and fixes are well documented. The door latch issue is pretty high up there on the PITA factor, but Rimmer Bros has the latches at 1/10th what they are going for in the US and after you've done one, the next one is < 1 hour work.
I changed the outstation when I redid door do not remember whether it was new or used think any chance it is the problem? The CDL switch is part of the new door switch I replaced correct, I am thinking about replacing wiring and everything in the door again and seeing if this corrects the problems. I can use the truck as it is just have to turn the key to the left to unlock driver door and use remote to disarm truck and unlock other doors and drive, but if I lose power for any reason I have to remove door panel and ground 2 wires and that is a pain. I have tried the contact that was left in this post about RF block but I just get not in stock message.If turning the key either way locks the doors, the CDL switch isn't working. The keyswitch is operated when the key is turned, irrespective of which way it is turned, just that it is being turned, it is the CDL switch that tells the door outstation whether the key is being turned to lock or unlock.
