1 - 12 of 12 Posts
2001 p38 4.6 v8 range rover parked in under ground supermarket carpark has locked itself out key remote wont work the we button lights up but doesnt do anything, so Unlock truck with key in door and alram sounds . put key in ignition and turn alarm starts again and says push key buttom push that it does nothing everything was working fine when i locked car to get get groceries now truck stuck there and dont no what to do to get it started as i have no manuals for truck
It sounds like the drivers door latch has failed. So when you unlock the door manually, the key switch isn't triggered, so it thinks its being stolen, immobilises itself and sets the alarm off.
The only real way of fixing it is to replace the door latch. I don't know how easy that will be to do where it is. Are you able to leave it in the parking whilst a latch is found?
Otherwise it might be a case of having to get it recovered (somehow) to where it can be worked on.
Depending on how technical you are, it could be possible to pull the door card off and 'mimic' the door latch key switch whilst operating the remote to fool it onto thonong the key is in the lock whilst you try to sync the remote. But it might not want to do it whilst alarmed..
Either way the door card needs to come off, I don't know the reaction if you pull the battery to work on it...
Marty
Sent from my S4
Haha never simple Aye I have road side tows for free with insurance but problem is car park is under ground so tow truck wing fit will have to tow it up above ground to be recovery trucked to my place will it tow 50 meters or so in neutral
Yes, it can be towed in neutral. There is usually a fuse you can put into slot 11 to put the transfer case into neutral for towing. You put a 5A fuse in, turn ignition on, and it should move the transfer case into neutral. Turn ignition off again, and it will stay in neutral until the fuse is removed and ignition is cycled again.
However, I'm not 100% sure if this still works again, as the vehicle is alarmed/ immobilised. If it's only a short tow, then it should be fine to just put the transmission in neutral and do it that way.
Best of luck!
You'll have to pop the door card off at some point - you might be lucky and find there's just a damaged wire in the loom, as they sometimes get swiped by the window mechanism. But of it locked OK, then it does sound like a failed latch.
Marty
Sent from my S4
Best of luck!
Marty
Sent from my S4
Hi Marty got it to go by putting key in lock and sync key fob it flashed the Indicator so I put key in ignition and it started but key fob buttons won't lock or unlock door still but key locks and unlocks and also disarms alarm
Good to hear!
So have you got it out of the car park and back home?
Now is the time to start doing some tests on the door latch and the micro switches inside it to see what has failed.
http://www.p38rangerover.com/central-locking/door-lock-actuator.html
That site has a load of information on testing the door latches, that page is the first page about the actual door latches, but on the menu on the left hand side it has individual tests for each or the internal micro switches in the latch.
I personally unplug the outstation when doing the tests (with the vehicle unlocked) as I've found that when the latch is unplugged (with outstation connected), the vehicle then locks itself. Its not a problem, as it re-unlocks when latch plugged in again, but if you're having lockout and alarm issues, then unplugging the outstation temporarily will stop the 'lock' command getting to the BECM.
If the latch fails any of the tests, then it's time to find a replacement.
If the latch passes all the tests, the try each one also with wiggling the handles, sill lock, and key in the lock in case there's something loose in the latch causing an intermittent problem.
If the latch still passes, then the next place I would check is in the gap at the door hinge where the cables go into the vehicle body (in the rubber cable tube) as there is a connector in there which goes green and can produce issues with the outstation communication to the BECM. Though if this was the issue, I would expect the mirror to stop working too, as I think (from memory) those commands are sent via the outstation aswell.
Hope this helps,
Marty
Discussion Starter · #7 ·
Yep car hm now an key fob has started working again could it of been the fact it just had bad batteries and need resync will pull door cars off in weekend an check it out
I would definitely be looking at it sooner rather than later..
Take this as a 'lucky break' and make sure your door latches are OK, and the wiring is good. You had a stroke of luck that it decided to work again. There are plenty of threads on here about people who have not been so fortunate, because they haven't fixed the small problem when they had the chance, which has then turned into a bigger problem.
If your key didn't unlock/turn the alarm and immobiliser off when used in the door then SOMETHING isn't working right. maybe it is a sticky micro switch, or a chafed wire - but the outcome of this for most owners who haven't taken the warning signs and delved into it a bit more and fixed the issue have usually ended up with a completely locked BECM, which then requires removing from the vehicle to be sent away for specialist unlocking.
My words of advice... I personally wouldn't be using the vehicle until I'd got it sorted for fear if it happening again, further from home or in an even more remote/difficult area...
Marty
Hey Marty,
I have had similar issues. My keyfob is damaged and I am attempting to "repair it" by switching out the internal "card" with another keyfob in working order. Do you think this might provide a solution? Also, I apparently have a bad rhd latch as it is increasingly difficult to open. Is that the type of thing a hard working amateur might repair himself? Thanks for any input.
Hi
The latch replacement is a fairly easy replacement for a DIYer, if not a bit fiddy.
There are 3 rods and the internal pull handle wire to disconnect which require a bit of twisting and wiggling inside the door, and reattaching them all inside the door can be a touch tricky, I was cursing a bit the first time I did one, but you get the knack of it pretty quickly!
You need a torx head bit to undo the latch itself from the door, but that's about the only out of the ordinary tool needed.
Hope this helps,
Marty
No worries. Good luck getting it sorted!
Marty
Sent from my S4
1 - 12 of 12 Posts
