I presume using the EKA code does not solve the issue.
If you have tried this unsuccessfully,then I think your BECM has gone into "alarm lockout".
The bECM will have to be unlocked(electronically ,after being removed from the vehicle) and then reprogrammed.
BBS does have a specific module to do this and ,I think that is what you are refering to in your post
My BECM went into this condition after it had been off the road for a time ,when I had it shipped from South Africa to the UK.Strangely it started and ran initially for two days and then went into the locked out state.
A local independant tried to access the BECM with a Autologic but could not do so,although he could talk to other ECM,s.
I removed mine and sent it to Rick the Pick who unlocked it and reprogrammed.
Good Luck
Good Luck
