Hello Folks! I am brand new to this board, although I have been doing a lot of trolling over it the last couple of weeks. Lots of good info.
I also have a similar post on a Jaguar motor forum.
I have a 2012 RR 5.0 with an AJ 133 engine that overheated so badly that the motor needed replacement. I replaced the motor with a Jaguar AJ133, which was the same motor that was in the Rover . I swapped over the oil pan, pickup and exhaust manifolds. I used the original wiring harness from the range rover and am using the original range rover ECU and key.
I do not know why this is happening, but it will intermittently crank over and has a "cannot communicate with ecu" code.
I have tried using the other ECU from the Jaguar motor and that comes up with an "incorrect vin" code.
Do you think flashing the ECU would fix this?
Thank you in advance to anyone and everyone - suggestions or help greatly appreciated.
The hardware (motor) shouldn't make any difference.
As you noted, it was necessary to replace the engine harness as the connector plugs to the ECM are different, which means you should be using the original ECM.
FWIW, ECU's can't be "re-flashed" (but SDD can load the security aspect of the original VIN's software and get the vehicle running for a while) between vehicles long-term so buying a used ECM on a MY2010-2012 is a temporary measure at best.
Thus, it will operate for a short while but eventually the immobilizer will throw a code and the CEL will illuminate due to incompatible VIN's.
If you have access to SDD, run the immobilizer program again making sure that SDD identifies/reads the original VIN, then run the program with it's original ECM and key.
That should ensure that the car should start and run as delivered, regardless of the engine hardware you've replaced.
Make sure that the two large ECM connector plugs are fully seated. If unsure, withdraw them both and check that the ECM's pins are all still vertical and one or two haven't been bent.
There is also a shop test called a pin-drag test that you might want to consider.
Although time consuming, the idea is to ensure that the female pins in the two connectors are not too "loose" for them to wiggle on the ECM's pins and create intermittent faults.
You remove the two multi-pin connector sockets and, with an appropriate sized male pin, insert that pin into the female pin(s) and see how "tight or loose" the female connector is.
Rob
Rob. Thx for the advice on checking the connectors as my incorrect trans overheat message and subsequent distress to the trans and motor may be a result of a loose pin losing the connection momentarily. Getting a used trans controller to see if any possible chance the trans computer is toast. I have checked the trans temp sensor numerous times and always comes up to the spec resistance that rrphil has provided. Next step will be the harness of this does not solve.
@mikeg137 was this swap a success? would you mind sharing any obstacles? I’m thinking about doing the same same swap considering the jag engines are so much more affordable than the RR version, I understand it’s just bolt on parts difference with the sump pan and pickup being the major ones, anything else?
Pretty easy swap/install from Jag to LR.
You’ll have to tap a 6mm thread into the lower engine block (hole pre-drilled) to secure the extended oil pump pickup pipe (Jag has oil pickup biased to the front of the oil pan, LR biased to the rear).
The LR has two serpentine belts, the Jag uses a single belt so you’ll need to swap the LR crank pulley and reuse the LR pulleys and tensioner.
The Jag power steering pump oil supply fitting (hose from the reservoir) is oriented such that you’ll either need to rotate it in the pump or use the LR pump.
Use the original LR engine harness.
Install new output oil seals on the front diff while the driveshafts are removed.
Swap the exhaust manifolds over from the LR engine before installing motor.
Use the LR starter motor - different electric connector than the Jag for the crank signal.
That’s about it.
Rob
