I trimmed my airline-it's been trimmed to the point that the little flare typically sitting about a half inch off the valve block collet is now pressing against the collet. I think this is why it's still leaking-I removed the sharp edges, sanded lightly, new orings inside, etc-all the usual stuff. Has anyone else run into this? How did you extend the line or solve the problem? Man I miss Dennis! :)
Yeah. We miss him also. As a small business owner I can empathise. There is a coupling that you can use to join in a new lenght of pipe. An old post on here, years back showed the coupling as did dennis. I bought some 6mm pipe from him but have not used it yet. I know that the CNC counter top cutting machines use the same air line and connectors as I have seen them in the shop where I get the odd counter top done. I do not know offhand but that ref might be meaningful. I am sure that you will find something with an internet search or ask the counter shop who does their repairs and supplies part. also some UK parts houses will have them
Use pencil sharpener to taper the end.
6mm hose $1.95 per foot:
http://www.jewellamberoil.com/sales/index.php?main_page=product_info&cPath=65_67&products_id=242
6mm connector: $8.95 each
http://www.jewellamberoil.com/sales/index.php?main_page=product_info&products_id=193
or $64.95 kit (4 connectors and hose) from AB
http://www.roverparts.com/Parts/RQM000030G.cfm
