If the outside temperature sensor is open circuit it will show -40 deg C.
I would check the sensor connection first.
If it has been disconnected then re connected It seems to take an average reading over a period of time so takes a few minutes to stabilize at the correct outside temperature.
It sounds as though the compressor is not being called to switch in because of the falsely low outside temperature.
