Hi,
I have a RR L322 04. Dash board is showing air suspension inactive and HDC inactive with ABS light no.
When the car is cold, this problem does not occur immediately. It occurs only after driving for 15 minutes or so. When the car is warm, this warning pops up right after I start the engine. Both messages shows us as the same time. I changed the ABS Wheel Sensor, but the message did not go out. Does anyone have any experience on this issue??
Re: Air Suspension Inactive & HDC Inactive for L322 03-05
Was your abs sensor picked out as being a fault ?
If like all my abs rings were they are maybe revoling round in the hup getting a little warm scuffing the interior of the hub. If you have no history of when you last needed abs rings then I would suspect they are shot . If its possible to have a look at the rings with the sensor out , the fault will show that they are shiny or cracked . Did your diagnostic only come up with one sensor .
