41 - 46 of 46 Posts
Hi, I have just joined as have similar issues with my 04 4.4 L322. Intermittent Brake lights/ABS/Suspension inactive, brakes pulsing on while driving, prior to warning lights coming on.
Garage charged my £700 and advised changing ABS ECU - duly replaced with a recon unit but same fault reappeared straight away.
Have had wheels aligned, new tyres on front, changed Yaw sensor, measured ride height at all 3 levels (which seems consistent across fronts and rears).
The air suspension pump seems to be struggling, as although the suspension moves between levels fairly quickly, the cabin switch takes a long time to extinguish. Have ordered recon kit/seals for compressor.
The warning lights now come on when I start first thing in the morning and stays on as I drive, but the brakes no longer pulse on. But after stopping the car after a short run, the lights stay off the second and subsequent times that I start the car and remain off throughout the day - only to come on again the next morning.
I have no idea what to do. Does any one have any ideas please?
M
Had this problem on my 2006 L322. Initially replaced the battery with no success. Turned out to be a faulty ignition switch causing intermittent contact to accessory power.
I disconnected the battery to work on audio and after connecting the battery back on, i see the exact same error as many have posted here. Prior to me disconnecting the battery, everything was fine....not sure what to do at this point?
Discussion Starter #44
turn the steering wheel lock to lock.
I had this issue on Rover 1 twice. First time was 4 years ago...replaced with a brand new Steering Angle Sensor (SAS) and it fixed the issue. 6 Months ago that SAS failed with the exact same symptoms...replaced it again with a brand new SAS and problem solved. I understand the failure symptoms but what is the failure mode? What is causing these SAS sensors to go bad?
This morning, I started the car and all my error messages went away. I hope it stays that way.
41 - 46 of 46 Posts
