Hi there,
Hope someone can help me out. I went over a pot of water yesterday, and the "Air Suspension Inactive" code came up at the dash. I have tried to do what showing on youtube by starting up the car then turn the steering all the way to the right then to the left. But the code remain on.
Hope someone here can help me reactive the Air Suspension.
Thank
Someone told me that it could be water in the wiring connector which created the fault.
Can anyone tell me where are the wiring connectors located, so I can check it out before spending the money to get the decoder.
Thanks !!
Folks, using a gizmo to reset the code does not fix the issue. All you are doing is hiding the issue until it gets worse. Get proper diagnostics if you are going to work on your own rig. Then you can identify the actual issue instead of throwing parts at the system hoping something works.
I would start with checking under the spare wheel where the air compressor is, when mine failed this area was full of water.
Mine has been inactive since the very cold temps this past winter, and tried the resent with a Snap-on scanner but that was a temporary fix, I need to take it to the stealer to get this done, right now is in the up position the switch does not activate the suspension. Very depressing issues
