1 - 1 of 1 Posts
The suspension on my ‘06 L322 has been working fine until I lowered it to do some work on the rear camera. Now the light on the knob goes on momentarily when I start the car, the goes off. When I try to raise the truck an “air suspension fault” message comes on. When I check the settings screen it says it is in Standard mode, but looks like the front is not quite up to level, and won’t go into a higher mode. I can lower it to Access and if I shut the engine off, turn it back on and before the light goes out, raise it, it shows “raising” and goes to the original settings.
Any ideas will be appreciated.
1 - 1 of 1 Posts
