Hi,
I own a 2004 RR, VIN 4A141872 with 198,000 miles with a problem. I hope someone can advise.
New battery installed and have 14.4 volts at 2000rpm.
After 20 minutes of driving straight roads then slowing down and rounding a 90 deg corner, the DSC, ABS,Trans Failsafe mode & Air suspension Failure errors appear. After stopping and then restarting engine, I can still drive normal speeds (Trans Failsafe disappears) and the only issue aside from the dash lights is the suspension rides low. If just left overnight, all appears well the following morning. Error messages gone and the suspension pumps up. Also on other occasions, after disconnecting neg earth strap, all errors messages disappear and can drive normally until the next slow 90 deg corner.
With an Allcomms module several errors are detected (Can Bus missing node - ABS ECU, Steering angle sensor -Incorrect CAN message, Anti-lock Brake Faults: ABS ECU, ABS supply) and all errors clear except Air Suspension - CAN bus Fault. I rebuilt the suspension pump and perhaps I need to replace the front suspension airbags since they do sink .5 inch overnight. Just need advice as to course of action. Thanks, Bill
