My front right airbag has a leak at the brass coupling connector I removed the air line and tried to remove the O rings but there were none I also checked my FL and there were also none do i need to change the whole spring because the coupling is leaking?
When you take the brass airline sleeve out and peer inside the airspring, you should see an oring in there. If you don't you have a problem. If your airspring was atleast holding some air prior, I can't imagine that the oring would be completely gone. If it is though, it's an easy fix. Just push in a new oring in.
