This morning I was checking the oil and noticed there was moisture on the top of my air dryer and around the collet of the air line..... Its about 25 degrees here. Is this normal?
If not, can the O-Rings be replaced without emptying the air system? (Cannot find my EAS USB hook chord at the moment)
RIP Our Friend
When temps drop you will often find moisture/condensation in odd places that you normally wouldn't think of. Think of it much like the A/C lines being frosted over in the middle of summer.
Quite true - so you wouldn't be concerned about it?
I do have a couple 8mm O rings laying around, so if I don't have to de-pressurize the system, I can quickly change them out on my lunch break haha
Can someone confirm this for me? Do I need to depressurize the system in order to detach the air line that goes to the air dryer?
JACK'S GRANDAD
You can, in a pinch, raise and lower the rig enough times to pretty much drain the tank. Then remove the line and fit the new o ring etc. Wont throw it into a fit that way, so long as you leave the drivers door open when restarting the rig, to allow it to fill the tank before any airbags.
I would not be without a manual inflation system, along with a schrader valve for the air tank, on any P38 I owned.
Martin
