Hi, how did you fix the problem?
Mine stopped today and it won't get cold.
Hi, if it is not cold. first to check will be the gas. If the gas is low can top up and monitor. If the aircon is cold after topping up then monitor the gas. If the gas is low again after a while then it may be some leak. Pray is the gas and not compressor or blower .
