Hello all,
Here are some easy questions. I've read the section in the handbook relating the Air Con and my understanding is that when the the light is on then the Air Con is off. This appears to be right as this the only setting that allows the fan to be completely switched of.
However today I thought I'd switch the Air on (light off) but it didn't get cold maybe needing a recharged which is fine but should the air circulation light automatically come, which I assume is shutting off the air entering the Range.
When I parked up thought I would do a sense check I.e. switched Air Con on (light off) and the engine rpm increased which I would expect to happen when it's switched off.
Never used the Air Con in my last mk2 but the Air Con light was constantly illuminated.
Many thanks
Garry
Many thanks
Garry
