Can someone recommend an air compressor refurb kit please on ebay in the UK. Am not exactly sure which one will fit this car anymore? Or is it the same compressor as the normal L322?
What compressor are we talking about - Hitachi or AMK?
If Hitachi (I do not know about the AMK) go to these guys - https://x8r.co.uk/products/land-rover/air-suspension-repair
Not no kit covers everything. You need new desiccant, filters, piston glide ring, piston ring, (you normally get these in the a kit) - you also need a metal desiccant metal cap and an exhaust valve and housing. These last items are normally purchased separate to the kit. There are other parts you can buy but are normally used if there is a mechanical failure - eg Cylinder and conrod etc.
Garry
does AMK come as standard? Or is it an upgrade?
The Hitachi was fitted up to about 2009 (you need to find out when exactly) when the Hitachi factory got knocked down in a earthquake so LR replaced it with the AMK. Some people have replaced old Hitachis with AMKs so before you go buying parts you need to find out what compressor you have - google pics and compare what you have fitted.
PS - I see you have a 2006 so it would originally been a Hitachi unless someone has changed it since.
