Hi there
After some adjustment to the timing, my engine runs great when the AFM/MAF is not hooked up. As soon as I plug it in it runs fine on idle but once in gear and driving it pops like a misfire and air/fuel mixture issue.
The unit was showing 1.88v which is a bit higher than the target 1.8v. I noticed the screen is missing and not sure if that would be a factor. Im going to have the vac system smoke checked for leaks but would a vac issue cause trouble like that?
any thoughts?
thanks
any thoughts?
thanks
