Hi guys, i'm all set with the parts I need for fluid changes for transfer case and front/rear diffs.
Now, i just need some advice on the fill plug locations on the 2 diffs and the transfer case.. Also, a confirmation ont he drain plug on transfercase would be mighty helpful. Any how to's also very much appreciated. I checked Atlantic british's videos but none of them were for the 2010 RRSC..
Thanks so much!
spikespiegels, do you have el.locking rear dif. ? (wires coming out on top of dif. case)
if so it needs special oil-Castrol SAF Carbon Mod Plus, if not I use Mobil 1 75W-90 full synthetic oil, transfer case oil is - Shell TF 0753. before you drain oil make sure you can unscrew filer plug first. putting plugs beck in use some Teflon plumbers tape on the trades. Have fun.:thumb:
Buba,
Thanks all. Just drained F/R diffs and transfercase, measured the fluids and saw around 1.5l for Rear diff and transfer case.. The Front diff however had a tiny amount of fluid which was a bit alarming, half a liter to be exact.. Can someone verify how much fluids need to go into the front diff? Thx!
