No, that is not likely to be the cause. The most likely cause with that warning is a loose wire going to the sensors above each wheel under the hood. This is a very easy fix.
This is the idea:
O
This is the idea:
Ok thanks.
What about the L320 ?
So they cut at same place on strut ? They are not accessible as the L322.
I will have to remove the wheel to check it ...?
