Seem LR is pushing some of the options upstream to the AB. ARD not an option on 14SC was on the 13
Re: Active rear differential not an option on 2014 SC anymore
The US catalog on page 66 shows the active locking rear differential (option code 027DB) as standard on the AB and not available on the RR, HSE, and SC. On page 69, under the option packs, it lists active locking rear differential (option code 028FA) as standard on the AB and optional on the SC with a footnote that it is not available in the RR and HSE. Curious.
When you do a build out of the 2014 SC it doesn't show ARD as an option. Yet I remember that it was a option on the 13 SC and 14 SC when it was first out. Seems LR make these changes to push the AB. Wish the 13 SC was around seems like the better choice
Looks like LR dropped the ARD option from SC, recently. It's only available on the Autobiography. So the SC and HSE are similar except for the engine
Thanks. So the SC has more the V8 motor and ARD over the HSE. Looks like I am going for the SC if available
