2015 Range Rover Sport 3.0 Diesel.
Air condition don't work. Low side pressure is too high and high side is too low. I think that the termostatic expansion valve is broken. I think that this part is difficult to reach. Does anyone know how to replace this part? Car is 1st gen Range Rover Sport 4.4 V8 petrol.
Best Regards,
Juha
FINLAND
Discussion Starter #2
Now I know the location of expansion valve. It is near to evaporator. Almost the entire dashboard must be removed. **** it:evil:
Welcome to rover ownership :lol: What are your pressures? Just because your compressor is turning doesn't mean it's working.
Thank you, Rover has become familarm both good and bad. Fortunately, I can fix it myself. Yes I know if compressor run it doesn't mean it's working, but I think that it's working. Sometimes it gives a little cold. Lowside pressure is 85 psi, when engine don't runing. When I start the engine and compressor runing lowside pressure decreaases slightly to 75 psi, at same time the high side goes little up, but not enough. I can't remember exactly high side pressure, but it is not much higher than the low side pressure. I have to check compressor before I'll start changing the expancion valve. I still have to think about how i could easyli check it out.
Only way to know for sure is to pinch off a refrigerant hose or replace the compressor. The hoses are really stiff so you won't be able use pinch off pliers on them.
2013-2015 Range Rover Sport
Compressors are really common on these. I have replaced one a week for the last few weeks here in the shop. Doubt the expansion valve has an issue, Have not seen one fail yet on one of these.
