Is two AC fan in front of radiator supposed to work constantly while AC is on? Or it cuts off and switch on automatically while car get slight overheat?
Fans come in when a certain pressure is detected within the AC system, in other words heat will build up more pressure and the switch will kick in the fans
Hi
In the ETM from the RAVE you will find the schematic diagram, This shows what Viperover already pointed out and on top of that also a circuit that let the fans come on with a signal from the engine ecu when the temperature becomes too high, See page 222 of the Electric Troubleshooting Manual edition 1995
Regards
Jos
