1 - 1 of 1 Posts
I used my AC recently and, after turning the car off, a stream of water decided to drop from below the dash onto my passenger side floor.
I pulled off the panel and it’s not a clogged line or bad connection, instead it appears that the dash has cracked behind and along the nipple where the drain line connects. I’m wondering what would be the best compound to seal the crack up? Pic shows the crack along the edge but it also extends to the base of the
My hope is that I can glue it back together, in place, and the leak will stop. Otherwise, I think I have to pull the whole dash apart?? No idea where to start on that.
Hood Automotive tire Bumper Automotive design Automotive lighting
1 - 1 of 1 Posts
