I sealed my ducts with Good Quality 3m duct tape. The cheap stuff will fall off.
The blend motor wont affect your ac but the temp sensor may. It is right on the heater core tube behind the glove. The high and low will read the same until the compressor kicks on. I also used some foam but mostly connected everything with the tape. My pressure is great. It was only good before. You could try a regas but if you think the orings are bad it will leak out anyway. Check your Nano for Hvac setting values that AC GRANT= YES . Then you know it is trying to run.
Good Luck
Good Luck
