Ok so I need to replace the fan belt on the AC (compressor) it looks like to me I have to
1. Pull fan shroud
2. pull fan
3. remove fan belt
4. put on the new belt
5. replace the fan belt
etc etc -
am I seeing this correctly, seems like alot of trouble for the AC belt - but since its 103 today - and summers just getting started - time to bite the bullet!
i would say no you dont have to pull fan or shroud...the ac belt has a ridgid tensioner you loosen that to remove belt...but if....and i woulod have to look.... there are other belts in front of that belt...i believe the fan belt...
remove that first..it also has a tensioner....but if you want ease of access......pull the fan and shroud....but not nesacery....
i know spelling....
good luck
mike
I don't know Mike, seems to me i would need to get the belt over the fan, then magically pass it through the fan belt. tough to do - and its too short to go over the fan as well. The AC belt is behind (the back pulley)
1995-2002 Range Rover Classic
it can be done the way Mikieman suggests, but it is much easier with fan and shroud removed, better and easier access to install and tension.
