Initially I had a problem with the power assist on my 2000 Range Rover. I replaced my accumulator, changed the brake fluid and blead the brakes. The brakes are working now but the brake, ABS and TC lights come on. Sometimes right away after starting the engine and sometimes after I start to dirve. I've dirven the truck for about a week now and have noticed brake fluid leaking from one of the brake components mounted just below the master cylinder/modulator mounted on the rear of the left inner fender (see photo). Today I noticed quite a bit of fluid on the floor just behind the front wheel. Can anyone tell me what this component is and why it would be leaking?
