I'm experiencing the common ABS/Traction Control failure warning. I only get the warning when the car is stopped, like at junctions or traffic lights, but not every time. Never while moving. Next time I start the car, warnings have gone......till the next time.
Thoughts?
Sounds like the warning is coming up while brake is engaged. One possibility that I can think of is weakening ABS pump motor. When was the last time that the electric motor was serviced or replaced?
Something to check is the accumulater, if your pump is running more than it should. It has gas to store pressure.
The gas fizzles out slowly. The light can show for that. Good Luck
The complete ABS pump and accumulator unit was replaced about 3 years ago, new and genuine.
FOUNDING MEMBER
Are all the three amigos showing or just the ABS and Traction warning lamps. If the brake warning lamp is not showing then I doubt it is the braking system causing the fault and will be either the ABS ECU or a wheel sensor or the cabling/connector twixt ECU and sensors.
if it is the cabling, connectors or wheel sensors then I would expect the fault to be permanent. Due to its apparent intermittent behaviour I would suspect that the ABS ECU is on the way out.
