I noticed a whining pump and have found that brake fluid wasnt making it out of the reservoir, so i cleanedit with 2 cans brake cleaner and 2 cans electric cleaner and then also swished with 1 can brake fluid, it still doesnt seem to be flowing fluid out of the reservoir, is the reservoir by chance an item that is under pressure when on?
thanks,
damthrill
The catch screen is most likely clogged. The only way to replace it, is to replace the whole reservoir.
Refer to the link below to my blog, nose around and you'll find the section on this reservoir with detailed pics
Replacement is highly recomended and you'll see why
